Sign in to follow this
chad
E30 325i flywheel issues with M20 swap
4 posts / 555 viewsLast Reply
(edited)
Has anyone ever received a bad clutch disc with a Sachs kit?  I when to put the clutch (E30 325i) and transmission in last night for my M20 swap the alignment tool would only pass through the clutch disk about 3/8 to 1/2 inch before binding up.  I double checked this on the input shaft on my transmission (Getrag 245) too and had the same thing happen.  I also double checked P/N on the E21 323i and the 228mm 2002 clutch discs and they are the same part number.
Edited by chad
(edited)
I just ordered a replacement kit so hopefully that should fix it.
Edited by chad
Are there burrs on the splining?
I've had to file minor ones away- the splines are broached, I think...
(edited)
No burrs. It wouldn't fit on my spare G245 either which tells me something is wrong with the disc. Compared to the old one you can see that the spline on the disc is off. The teeth are noticeably short and wider. I am going out this afternoon to get the part number on the disc to try and reference to see if the wrong one was put in the kit.
Edited by chad
