sport springs what brand has the best value for your $$$
eibach, h&r, suspension techniques, korman, alpina, dinan, etc....????
i am planning on using it with bilstein sport springs too. are urethane bushings better than stock rubber bushings? how low is the drop on the springs
i am on a limited budget too.
Don't waste money on springs until you buy coilovers. They won't be exactly what you want, you won't have adjustability and the moneys gone. Also don't worry about what name is on the box cause none of them make thier own springs. I wasted hundreds of $$$ to figure this out. I ended up with stock springs cut 1 1/8 coil off the front and 1 coil off the rear. You can cut them with a saw or torch. At this length the fronts won't fall out of the struts at full extension with stock length dampers. The car is more than an inch lower, more in front than rear. Its quite a bit stiffer and the price is right.
lots of variables involved, including shock valving, tire size and aspect ratio (the shorter the sidewall, the stiffer the tire rides but the more stable the contact patch is) sway bar sizes, bushing deflection rates, spring rates & whether the springs are wound progressively or not, etc, etc, etc.
It generally works best to determine what you want out of the suspension set-up first, then work backwards toward the best setup for the intended purpose. The 320 parts car I just acquired has short, stiff springs and shocks, big sway bars and relatively wide 50 series tires on 15 inch wheels - it corners like a go-cart, but rides like one too (no way I'd want to live with it on the street every day).
