I spent 4 hours cleaning some over spray inside the
IT IS ASTOUNDING SOMETIMES WHAT PEOPLE WILL MASK WHEN THEY COULD REMOVE IT IN HALF THE TIME !
OUR 2002A WAS MASKED AROUND THE GRILLS ! THEY GOT
OVERSPRAY ON THEM AND IN SOME PLACES NOT ON THE CAR .
FOUR SCREWS AND A WINGNUT GETS 'EM OFF SO YOU CAN MASK & PAINT PROPERLY .
I am plaining to paint my 528e soon, and I thought, if I get it painted I am going to remove as much trim, glass, mirrors, grills, lights, bumpers, etc.
I even thought of going ahead and fixing the dents, etc myself.
That way, I dont have to worry about overspray.
Just a thought,
Lyle
but I told them dont paint inside the trunk or engine bay and they did, and all my redone harness all wasted. Took hours to get the engine harness.
...I got it in 2001.
I've since cleaned things like the door, hood and trunk latches, the windshield wiper mounting posts and nuts and other assorted things that must've gotten in the way of the painter.
BTW, the car was last painted in 1984, so all of that overspray protected a lot of things from the elements for nearly twenty years. So despite the many hours I spent cleaning it off, it was actually "a good thing."
Delia, Julius and Red Oktober
some touch, and now again last month to fix a small hit. So I have 3 stages of over spray, even in the gas tank, and then they tried to cover it up by spraying more shit on it.
use tinfoil. Works like a charm and easy to remove once you're finished. My local body shop never heard of that 'till I told 'em (learned it from my auto body instructor years ago)--now they use it! Doesn't hurt to mask stuff off before you take your car in for paint, either. You'll do a much more careful job.
Mike
is with laquer thinner and 000 or 0000 steelwool. Usually takes almost no pressure to do the trick, which is good. Obviously, this won't work on everything, but it does work on lots of areas.
obsessive-compulsive perfectionist, you'll get overspray on anything that's still bolted to the car, no matter what you ask for. The only sure remedy is to remove it or mask it in advance.
