Accelerator lever arm source?
I just finished putting my rebuilt webers back on (which fixed my
problem from the post way back). I have been running a single
weber while getting the others setup. I had to change the angle of
the lever that attaches to the pole on the pedal box. When
readjusting back for the throttle cable setup, I'm having a lot of
trouble getting it to grip tightly, I think because the hole is bored
out a little from being messed with so much. It is holding for
now, but has already slipped once. Is this part available new? Any
good used sources?
TIA,
Dewar
'76 Inka -back on the road
If you look at the clamping area of the arm it has 2 little legs that come together when the bolt is tightened so that it will clamp firmly but not squish the rod, just file the legs a little and it should clamp tightly for you....Marty....
