Door panels.
I am making boards from 3mm baltic birch and
it seems like it should work fine. 27/64" is
working for plastic clip holes.
What glue should I use to hold vinyl to board?
I would like to replace the chrome mylar tape
trim. Any tips to get chrome tape on an looking
good?
Is double sided tape best for new plastic door seal?
Thanks
I use a glue called Rainbow glue. You can do a Google search to find a supplier, but be warned....it's pretty spendy. I apply it with a tool called a Glumaster. It's basically a metal oil can, with a brush attached. Also pretty spendy. You might want to consider a can of ProBond from the Home Depot.
Al
You can use the same contact cement to attach the plastic vapour barrier t othe door. Double sided tape will be OK, as long as it is very thin. You don't want it interfering with the panel itself.
Mylar? Apply it wider than you need, and carefully trim it with a razor blade, or sharp X-Acto knife.
Good luck,
Al
