Lee, one question about the in tank E21 fuel pump.
What I am basically trying to do is to keep the stock look and location of the in tank fuel pump for my sidedraft 44 mikuni's. My main question is what's the fuel pressure coming from that drop in pump or do I also have to use the secondary underside pump (above pass. side rear cv axle)
You will need a fuel pressure regulator to lower the fuel pressure. You will nt need the high pressure fuel pump located under the trunk floor.
This pump is very quiet. Depending on your tank, you might have to lower the fuel pickup screen by hafl an inch to reach the bottom of the tank. Easy to do.
