On the ol' speedo cable and some other 12:30 am ramblings...
Is there a replaceable seal at the tranny end for the speedo cable? I was under the car tonight and notice the connection to be rather loose and leaking oil. I plan on rebuilding the shift linkage and so with the driveline and exhaust out of the way; are there some common seals on the transmission that I should look at replacing while the back of it is more easily accessable? The tunnel & tranny has a good layer of gear oil. Since I'm going through the motions to rebuild the linkage, it would be a good time to clean up the area and handle the source of the leak(s).
I just installed the poly tranny mount tonight and noticed quite an increase in resonant noise inside the car. I can understand why this would be, but thought I'd see if this was pretty routine with going to the harder mount.
Opinion on rear shocks: With Ireland sport springs (stg II) will there be noticeable difference when going from KYB Gas-a-just to Bilstein Sports? I have the sports but haven't put them in the back yet.
Have a good night everyone.
the hole on the tranny. Try tightening it. It may solve your loose speedo cable problem (although, thinking from memory, I believe there is a little play in the cable where it attaches to the tranny..so the play you have may be normal).
Brandon
From past experience with KYB, I can attest that they are shit. There damping is very bad and their stiffness is due to to much gaz in the shock. The shock itself will raise the car by one inch compared to a regular shock, only because they are over inflated. Go with Bilsteins.
I was wondering if since I hadn't changed the rear shocks yet, whether this could be the cause of the rear end riding a bit higher than the front. This is promising.
