High beams out
When I push my left hand side stalk forward for high beams, they don't come on. Yet, I can pull them toward me and they will flash on, so it's not the bulbs. Is this my relay? Or is it the switch?
Thanks!
Are you saying when pushed forward they down hold in place and spring back or does it hold and not work? If its the fact that its not holding in place I would think that is was the stalk switch....but do some more diagnostic to be sure
stalk (presume this is a squarelight car with left side turn signal switch)but the low beams go out when you push the lever forward to select high beams, my guess is it's in the switch. If it were the relay or bulbs the flasher mode on the stalk wouldn't work either.
You might try taking the switch out and cleaning the innards with some "tuner cleaner" spray (get from Radio Shack or an electronics supply place). You might also find something overtly broken. Sometimes they can be fixed; other times...it's parts car time. Good luck
Mike
to go to constant high beam, you should be able to push forward and the stalk should remain "notched" in place. The pull/spring-back is to say hi to other BMWs( not used for last 20 years) or to say hi to other 2002s( used frequently), or to tell that POS in front of you to move over. I have not had to do surgery in that area- so if it is not staying in place when in forward position, maybe someone has a tech tip. Good luck: be sure to run H4 80/100s( relayed)- they illuminate very well.
