Hi,
  for the past two weeks i have been searching for a water leak
that really did not show itself. i had just about resolved to take
the head off and have it tested. so i statrted the car one more
time before i was going to drive it out into the rain we were having
and try not to make too much of a mess with the coolant. the car
is a customers regular driver and a tii which i had recently swapped
in a known good motor for her exploded one. i had the air cleaner
out and the motor was running and i saw a hint. the rail where the
oil pan bolts to the block on the driver side was now carrying green
fluid.   What did i touch in the last 30 minutes?????  well i tightened
hoses and even the "water outlet neck" on the head. i turned the car
off and followed a trail upstream to the spot where i could see fluid
weeping from the neck. when i put the motor in i replaced every hose
and clamp, and checked and cleaned every mating surface for the
hoses. this thing looked okay so i reluctantly put on my readers and
saw a leak coming from the water neck. so then 20 minutes later
and alot of very fast wrenching got me to the part and i had it off.
i just barely tested the flange and i had two parts. i do a ton of work
on 2002's but i have not seen it all yet. this was a sobering learning
experience. now i have to go search the bins for a spare to put on.
i just wanted to mention a small victory. i also need to wear those
damn glasses more often.
thanks for reading
stone02
post-35384-0-17965300-1454383896_thumb.j
post-35384-0-35451800-1454383953_thumb.j
These will break if the intake and water neck are not the same thickness where the washer sets.  Tighten the nut and the water neck side cracks.
Guess using different composition gaskets (on a tii) would cause this? Or using gasket sealer rather than a proper gasket?  I'm thinking the water neck would be more prone to cracking on a carb'd car that uses non-factory intake manifold.
Edited by jgerock
