Stuart
MSD 6 Mounting Locations
6 posts / 615 viewsLast Reply
All -
I am unsure of where I want to mount my MSD 6 ignition.  Mounting it on the wall of the engine compartment is one choice.  What I would like to get are pictures of it mounted in other less conspicuous locations.  Options I'm considering are behind the headlight, somewhere on the firewall.......etc.  Are there any other locations?
Any pictures and ideas are greatly appreciated.
Thanks in advance.
Stuart
Not an MSD 6 but similar principle. If you are extending the wiring to mount elsewhere, use soldered connections.
post-39712-0-22709800-1452324459_thumb.j
I don't have a picture but I mounted mine above the right headlight used s small piece of aluminum angle on the right side and the shelf in front of the rad on the left. I also mounted it using some old aircleaner rubber mounts that were lying around.
