puma1824
1971 BMW 2002 M42 Swap Project Car w/Original Engine & Additional Parts
3 posts / 1499 viewsLast Reply
(edited)
SOLD
I purchased this car about 2 months ago but haven't even had the time to pickup from the seller.  Due to some unforeseen personal issues I cannot continue with taking delivery and completing the project.
SOLD
Here are the details I know about the car:
- 1971 BMW 2002
- Originally White
- Complete M42 Engine, Transmission, ECU, driveshaft
- Will come with original engine.  Original engine pulled out of car in order to do a M42 swap.
- New 318 radiator
- New 318 fuel pump
- Starter
- Slave cylinder
- Jakeb Engine Mounts
- New water pump
- Misc gaskets and seals
- PLUS more see below
Original Ad Description:
My project has stalled, I don't have time and I need to move on. This is very much a project. Cannot be driven home. The engine is out and front suspension is dismantled for rebuild.
Originally white car. Very soild floors, fenders, shock mounts, around winows, etc. My plan was to do an m42 engine conversion. This swap is pretty well documented on the Internet. I have a ton of parts for the swap as well as for brakes and suspension. If you preferred, I have the old m10 engine and you could go original.
Parts:
Ireland Engineering front suspension rebuild including all bushings, struts, adjustable sway bay, etc. Ireland Engineering stage 2 springs for front and rear.
Brake rebuild kits for front and rear ( everything from calipers to braided lines)
1991 318is m42 engine, transmission, ecu, starter, etc.
Custom engine mounts
New radiator and fuel pump for swap.
Extra subframe and miscellaneous suspenasion pieces
Extra complete wiring harness
Original m10 engine and transmission
More I can't think of at the moment.
SOLD
post-49453-0-88091200-1452189872_thumb.j
post-49453-0-62550600-1452189778_thumb.j
post-49453-0-12217600-1452189779_thumb.j
post-49453-0-78857600-1452189779_thumb.j
post-49453-0-96765500-1452189780_thumb.j
post-49453-0-66686100-1452189782_thumb.j
post-49453-0-01538500-1452189783_thumb.j
post-49453-0-63704600-1452189784_thumb.j
post-49453-0-32691800-1452189786_thumb.j
post-49453-0-73038800-1452189787_thumb.j
post-49453-0-66432200-1452189844_thumb.j
post-49453-0-66141500-1452189845_thumb.j
post-49453-0-34506500-1452189846_thumb.j
post-49453-0-23738000-1452189847_thumb.j
post-49453-0-39580000-1452189848_thumb.j
post-49453-0-52062900-1452189849_thumb.j
post-49453-0-57852200-1452189850_thumb.j
post-49453-0-31268000-1452189851_thumb.j
post-49453-0-20792500-1452189852_thumb.j
post-49453-0-37069400-1452189866_thumb.j
post-49453-0-32392800-1452189867_thumb.j
post-49453-0-07065900-1452189868_thumb.j
post-49453-0-45770000-1452189868_thumb.j
post-49453-0-11452600-1452189869_thumb.j
post-49453-0-83969000-1452189869_thumb.j
post-49453-0-70258800-1452189870_thumb.j
post-49453-0-96149300-1452189871_thumb.j
post-49453-0-89202700-1452189873_thumb.j
post-49453-0-33173800-1452189900_thumb.j
post-49453-0-32650400-1452189901_thumb.j
post-49453-0-04426200-1452189902_thumb.j
post-49453-0-15824600-1452189903_thumb.j
post-49453-0-85419300-1452189903_thumb.j
post-49453-0-40744900-1452189905_thumb.j
post-49453-0-18655800-1452189907_thumb.j
post-49453-0-20583600-1452189908_thumb.j
Edited by puma1824
