vairter
separate carb priming electric circuit
6 posts / 570 viewsLast Reply
The previous owner of my 1975 '02 wired up the electric fuel pump so that it begins to operate in the "Fahrt" ignition key position.  I've been using this position for a couple of minutes before starting the car in order to fill the carb (Weber 32/36) fuel bowl since I only drive the car every couple of weeks.
I just figured out that this procedure will also apply power to the electric choke heater, causing the choke to fail to close fully before starting.  Needless to say, this has caused me some grief in getting the car to cold start.
Has anyone tried to run a separate switch+fuse directly from the battery to enable operation of an electric fuel pump without using the ignition key, so that the choke isn't simultateously warmed up?
Terry
You shouldn't need a few minutes to fill the float chamber of a carb with an electric pump. Few seconds max, assuming it's dry to begin with.
Yeah, 5 seconds.
But it would be easy enough to wire the choke to a circuit that's
only on in the run position.
Your meter is your friend.
I used a fuel pump relay from an E30. It allows the fuel pump to run only in start position or when there is a signal from the coil. Took some time with my multimeter and the E30 wiring diagram, but it works great and is safer in case of accident.
and for added anti-fuel-death, the inertia relays from '80s Fords are good, too.
We have do to it in our race cars.  We are required to run an oil pressure switch that kills power to the fuel pump in the case of no oil press.  We just wire in a momentary switch or button that bypasses the OPS to fill the carb so it will start without cranking for 10 seconds.
You only need to prime it for a matter of seconds 2-3 max.
