Sign in to follow this
2002Targa
Cheapie spot welder...
2 posts / 538 viewsLast Reply
I wonder how much force it applies to the pinch point. I've always been a little crazy/OCD and have lined up the panel, drilled holes and welded the panels together that way. I also usually try to drill all my holes first so I can take the panels apart and file them, then the hardest/most pita part is clamping the metal together.
A good spot welder should be able to really press/squeeze.
