bobthomas
Motor Mount Orientation
5 posts / 674 viewsLast Reply
I'm replacing urethane motor mounts on the M2 with stock mounts.  What is the proper orientation for passenger side mount?   Does the "pointy" end point to front or rear?  Is the gap or split or whatever we want to call it face up or down?  There seem to be locating tabs on the mount but no obvious holes for them.  Help, I don't want to put this thing in upside down & backwards.
Did you buy Genuine BMW/OEM mounts or aftermarket? I believe they only go one way.
OEM from Bluntech.
Thanks Buckeye.  That's exactly what I needed.  Helpful hint- when installing passenger side mount, be sure the locator tab on the upper mount surface in in the hole,then tighten the upper mount bolt, before tightening lower bolts.
