more coilover questions
i picked up a pair of coilovers that need new vw
rabbit inserts. anyone have an inexpensive place
to buy them?
they also came with the strut tube/spindle and
camber plates. is there anything besides new
inner and outer races that i would need to install
them?
thanks for any help!
how much did you pick those up for? i'm trying to figure out the total cost switching over to coilovers with camber plates. are they adjustable camber plates? what spring rate are you going to run? sorry for all the questions. thanks, evan
since it was a scorching deal from a fellow '02er
and not the norm. 75 bucks for the set including
strut housing, springs and camber plates. it does
need inserts though...
Assuming the thread at the top of the strut is still all 2002, where ever you buy them ask to swap for the 2002 gland nut (M48 x 1.5mm) which retains the inserts. The nut that comes with the Rabbit inserts is M50 x 1.5mm.
