Shift pattern transfers
Stan
I tried the sticker. It was great having 5 gears but those white edges were a constant reminder that it was only an illusion. I colored the edges black in a vain attempt to fool myself but deep down I knew the truth, it was only a decal.
Finally, I could take the deception no longer. I removed the sticker, forswore the overdrive, returned to only 4 gears.
Now I know what my engine is screaming at 80mph - TRANSFER, TRANSFER, TRANSFER!!
Please do this. I assume you can make them overlay the existing printing? A stencil with appropriate white ink would also be the bees knees.
Edited by gastephens
BMW Lotus Healey Miata x 2
My sticker (I tried 2 or 3) kept curling up and peeling off, no matter how much cleaning (alcohol too).  Gotta assure that it sticks.
I think $15. is well spent on a refreshed shift pattern overlay.
I'm sort of interested.  I'd prefer to spend more $ on a whole array of white transfers for shift pattern and other dash text.
Timely.  I've just started this same research for the switch names on the dash.  Early cars had none, 72 up had white text.  I have purchased an early crack-free dash for my 73 and need to put the text onto the dash to be correct.
Ganging up the die-cut pieces would cut down the prices, I believe.  It's not the material.  It's the cost of the die and the set up that gets less expensive the more copies you make.
Sorry to pollute the waters with a further request, but there might be some value in upping the order.
Lastly, it's CRITICAL that the process works.  Nothing would look worse than letters hanging off. :angry:
73 Inka Tii #2762958
In for two, one for my son's and one for my car
Dennis
Both 5 speed
Edited by zinertia
1975 BMW 2002 - Poly, coil overs, big brakes, rear IE springs, IE front/rear sway bars, turbo flares, strut braces F&R, limited slip, IE header, Recaro, stainless Magnaflo exhaust, rear spoiler, Minilites, 5 OD, etc.
