How do I check/adjust the timing???
I need to check and possibly adjust the timing on my 1972 2002. I have a timing light but don't know how to use it. It would be greatly appreciated if someone gave me a quick how-to or a link to where I could find some detailed info...THANKS!
The proper way is to aim the strobe at a ball that is pressed on the flywheel at... about 2400 rpm IIRC. However, since the advance springs in your distributor are most probably old and not at original spec, I would suggest (if u really need to adjust it) that mark the orientation of the distributor and then advance it a bit, until u can hear the motor ping under load(take a test drive), and then back it off until it no longer pings.
Cheers,
Ray
