Removing the Crankshaft Pulley on tii?
I'm disassembling my engine at the moment and have be caught in a snag. In order for the upper timing cover to be removed, the crankshaft pulley has to be removed. The nut was taken off, but the pulley doesn't "slide off". Is there anything I'm missing? The BMW manual doesn't help, it merely say "Remove pulley". There are the four bolts on it...do those affect it?
Thanks,
Philip H.
you are going to need a 2 or three legged puller to remove it. You should remove those 4 bolts and pop off the belt pulley, leaving just the tii pulley hub to pull.
The pulley is in 2 parts. The 4 bolts hold on the belt pulley..You need to take off the 4 bolts then you can remove the belt pulley from the hub and remove the front covers...
You don't want to take off the pulley hub till you get the cover off and the belt for the injection off.
