Time to come clean: I'm officially a Beemer owner
M3M3
THIS IS NOT JIMS FAULT!
My brother is the "enabler" here.  He and I had matching Yamaha RD250's back in our early twenties.  He lived in New England, I lived in Seattle.  He got a BMW K75s several years ago.  I got one today.  Of course, we still live on opposite coasts...he is in Seattle, I am in DC.  oh well.
I have been looking for a while, but finally pulled the trigger on this 94 K75s.  Will probably take it all apart this winter and refresh all the gaskets/hoses/brakes/etc.
and it is stored in the "den of sins" next to Jims 911....
2xM3
Nice pickup, Marshall.  Looks mighty clean, and the color is right...   :P
Sadly, while I rode for many years, I haven't ridden since I sold my Interceptor right before I got my 02...  Still miss the 'freedom' two-wheels imparts.
Tom
Where we goin’? … I’ll drive…
Thanks Tom.   Color....LOL.....Black and silver are the two colors that appeal to me the least.  I was looking for a red, blue, purple or yellow one...anything but black or silver.  But, as we all know....when buying something old, condition rules.  ya get what ever color comes on the old vehicle in the best condition.   up side with a bike though...easy to just take off the painted parts and get'em repainted.  not going there though, the paint on this thing is in perfect shape.  metallic black it is!   :)
spent 3 hours today cleaning, waxing, vinylexing, and conditioning the thing.  then fixed the sticking ignition switch and fuel caps.
then rode the thing 4 miles around the hood....no license plate yet...can't go far.
Edited by mlytle
2xM3
And pulled the saddlebags.
I like the "M" stripe on the seat.
You are really lucky.  I ended up having to replace the switches on both sides of my R90.  The hardest part was putting all the lines back in the right spot on the board in side the headlight.
I also ended up removing the points from mine, and installing electronic ignition.  I still need to rebuild and tune the carbs.
Too many projects.
FAQ Member # 2616
-- My wife.
this thing needs a full efi tune up.  thankfully from the messing i have been doing with motronic bmw car EFI systems, the bosch k-jetronic on the bike is pretty simple.  TB's need balancing, new spark plugs(same part as on the S14), new TB gaskets, TPS adjusted, injector cleaning, new intake/crankcase breather hoses, etc.  it runs ok now, but will tear into it this winter.
2xM3
Congrat's Marshall, stay safe on that. To come clean I'm looking at old air heads from the'50s and '60s to add to the collection.
Andrew Wilson
moved it to the shop for some maint..
first up...spark plugs.  same plugs as an S14.
old ones not too bad, but had been in there a long time.  the caps that go into the wires were totally corroded.
noticed one of the reasons the idle may be off, cracked crankcase vent hose...unmetered air going into airbox.
main airbox to manifold hose needs replacing also.
on to the brakes...full fluid flush front and rear.  this had not been done in a while either.  no way to use a pressure bleeder, but you can squeeze the brake lever/pedal with one hand while working the bleed valve with the other.  ez.  Moto MC's sure don't push much fluid.
rear abs
rear brake
front MC on handlebar
nasty old fluid
then took the "barbacks" off.  these aftermarket devices move the handlebars up and back about an inch and a half for a more upright riding position.  not my style.
done
then i changed the final drive oil to redline 75w90 and the transmission oil to redline MTL.
everything is so small!  not used to working things other than cars.
i understand the need for motorcycle lifts now though.  even sitting on the floor it is a pain in the knees and back to work on this thing!
will get to the throttle body adjustment next.
:D
no alumablast was used in the maint process!
Edited by mlytle
2xM3
today's fun:
compression check
temporarily fixed cracked crankcase breather hose (new one on the slow train from maxbmw)
TB's synched
choke and idle adjusted
then added new lic plate, not very original, but...
matches this one in seattle, owned by brother..
Edited by mlytle
2xM3
