Alternator harness & alternator
Tom1
rtheriaque wrote:
Yes, in my view, the whole harness to the voltage regulator should be refreshed with the proper colored Ga. wire.
The part listed above is not long enough so you won't be replacing 40 year old resistance prone, cracked insulation, incorrect colors, etc. wire which may affect the charging of the system.
I am not promoting myself; so buying the aforementioned plus is the quicker and easy solution to at least getting you back on the road.
Be sure to make up a new ground (brown) wire too; and if your car is a Tii, think about a new harness to the fuel pump that is 3mm Ga. as the OE Ga. is insufficient for the either the OE pump or any replacements by about 12%.
I made a whole new '74 Tii harness for my car, front and rear which will eliminate all those gremlins.
