Sign in to follow this
source for plated metric hardware on net?
12 posts / 117 viewsLast Reply
ultimate garage doesn't do it anymore. anyone else. Looking to get a good assortment of m8, m10 in various sizes.
i believe that regular zinc plated material is plated silver, I think this is the case here too.
Ideas?
..from what I have heard called "flash chrome" plating. Either way, the corrosion and wear protection is excellent. Both are done with the use of toxic metals & chemicals and are therefore no longer common except in industries where specified (also costly). The yellow colored plating as well as black oxide is what I find when purchasing hard/automotive grade hardware. If corrosion protection is important and you can get get by with a little less tensil strength, use 18-8 Stainless Steel (type 316 is not as tough). Heat treated alloy steel is often twice the tensil strength of stainless steel, but I use stainless steel on suspension components and elsewhere.
is zinc dichromate or (yellow zinc) according to the ultimate garage website standard automotive fasteners are zinc plated silver.
..oxide coated alloy steel, and some stainless steel. However, the automotive grade hardware that I purchased from my local Ace was yellow coated.
pieces and will send them off for plating and baking tomorrow.
of them done, cebause is done by a batch minimum.
