Sign in to follow this
Tii clock Repair?
13 posts in this topic Last Reply
Anybody had any luck trying to repair a tii clock themselves? TIA
Tim
by cleaning the contacts inside the clock, search it.
Has done it...not sure what year but I saw his instructions on his site
Thanks, I'll check it out
dang, '73. Oh well I'll try anyway. Thanks
inside the clock with some sandpaper and it should work again.
Ah yes, "pre" meaning before, duly noted.
I used a small flat screwdriver and gently pried up the bezel. Only need to go around halfway as it should then slide off. I cleaned the contacts and then applied 12v to test. When the contacts touch(as the clock winds down), the unit should fire and spring out. This is what winds the clock.
Mine would run for a while and then just stop before the contacts would touch and fire. Asz the problem was purely mechanical, I tried a couple of clock shops. Nobody wanted to try it, not worth their time. (BAD pun)
I went ahead and used isopropyl alc to clean all the pivot points and any dirt I could see on the gears. Better, but not done. I then applied just a drop of light oil on one pivot point at a time. After about 3 or 4 I had it working. I let it run open on the bench before I buttoned it up. Working now, but I just need to adjust the speed. Oh yes, and find one of the mounting brackets. The PO used duct tape to hold it in place!
Thats great, sounds like just the sort of story I was hoping for. I'll give it a shot
Thanks, Tim
I used a small flat blade screwdriver and worked up the edge
of the bezel that wraps around the lip of the canister. (You
can't
see the lip until you have the thing apart, but it's there.) Once
you have a start, it's just a matter of working the screwdriver
blade
gradually around the circumferance of the bezel edge prying
a little more each time around...it's slow work and you CAN
screw
up the bezel if you "ham-hand" it, I thought of it as "stretching"
the metal. Also, you will need to reverse the prying up when
you
reassemble, so consider that, too. I made a pad of corrugated
cardboard (ordinary box board) with a hole punched in for
the
center knob of the clock face, to work on. If you don't savor
the challenge of this, there is always the option of spending $
and
letting Palo Alto Speedo or No. Hollywood Speedo do the job
for you.
I took mine apart and fixed the broken solder joint that was
the prob...they are sealed, but the work-around is to gently
and
carefully pry the chrome bezel up all around the front until
you can separate the front from the "can"(thanks to advice
from this
board!). Mine is an old mechanical MotoMeter clock, but the
later ones look mostly the same. Palo Alto Speedometer will
rebuild these for $125 and up...I opted to save some $$ and
DIY. I have seen later clocks salvaged from late BMWs
offered for
sale, these are cheap ($40) but I believe smaller
diameter...however, you could MAYBE adapt one to fit the
larger hole with a
sleeve.
Lee,
I just did this several weeks ago and spent a lot of time
researching it.
I'm assuming you know that you can get the clock out through
the glove box WITHOUT removing the dash board (see the
archives, or reach around in there).
I used N. Hollywood Speedo and would recommend them.
They were able to transfer the original face from my
non-functioning clock to a new VDO quartz clock while I
waited, after I just walked in. They only charged me for the
new
clock (no labor), which was $150.- plus tax. CNPR wants
$175 for a quartz clock that doesn't look right). The VDO
clock with
my original clock's face fit right, looks perfect, and the
electrical connections were similar enough that even I could
figure it
out. Re-installing the clock in the dash is a PITA, but not
impossible.
Good luck,
Ben '74 tii
'98 CBR F3
Per Mike's book, page 156:
"Reparing a clock can be very simple, the hardest part being
taking it out of the dash. By removing some of the under-dash
panels, you can slip your hand up behind the clock and
unscrew the two knurled nuts that hold it to the bracket.
With the clock out of the dash, take the rear cover off by
undioing the small screws that hold it on. You should now
see the
mechanism, and if you look carefully you can find where the
circuit has broken. There is a point in the circuit where two
small
metal discs are, or should be, attached to each other (this
was probably intended as a safety circuit-breaker).
The discs can come apart and break the circuit that
energized the electromagnet to bring the arm up from the
bottom of its
cycle. You can check to see if this is the problem by attaching
the clock to a 12 vold DC source and using a small
screwdriver
to push the discs together. The arm should fly up to the top
and the clock will start ticking again. The repair is simply to
solder
the two discs back together."
: Thanks. This car was purchased new in Belgium, and I'm
glad to learn that the clock is probably original - now if I could
only get it to work!
The clock indeed is the most common option on european
02:s. Ive looked at four nonworking VDO original clocks and
they
have all had the same problem( very easy to fix!!!) The clock
is electro-mechanical, that is there is a mechanism for
"winding" the clock up, after that it runs for about five minutes
driven by a spring. When the tension in the spring is used up,
the arm touches an electrical contact and the spring is wound
up again. The culprit is (at least sofar in 4 out of 4 cases) this
electrical contact. There is a part made of spring steel that
should attach to the electrical contact- and this has most
often
rattled loose. If you solder this piece back together the clock
should work okay. To get to this part you obviosly have to
remove
the clock from the instrument cluster and open the small nuts
on the back of the clock (one of them is sealed, no warranty
after that :-) )
Hope this helps!
Benkku
IT HAS NOT MISSED A MINUTE IN TWO YEARS
BUT IT SOUNDS DIFFERENT .
