Sacramento Area Weber Carb Help
nsev
I have been troubleshooting my Weber 32/36 for the past couple weeks and have gotten it to run just not perfect. Either the warm idle or the cold idle is off cant get them both perfect. I was wondering if anyone in the Sacramento area could help me out and show me the tricks to the Weber.
Thanks
I'm in San Francisco/Berkeley so I can't be there to look at it.
And my best guess is that even having someone there to look at it won't be much help unless you have some background you could share.
You might be able to troubleshoot it over the board here if you have more info.
I struggled with a weber 32/36 for 3 years because I was too intimidated to take it apart to perform the standard rebuild kit.
I finally did it a year ago—turns out it's very easy and will give you a base line to tune from. CD's 'prescription' has worked great for me.
You'll know what jets you have and you'll have the ability to answer any questions that we may have to point you in the right direction once things are freshened up internally.
What are the symptoms? ie: what do you mean by not perfect? No one here has a perfectly running 2002—I don't care what they say! ;)
Have you checked the basics? Timing? All vacuum lines are intact and/or plugged off properly where needed?
Do you have any emissions equipment like the egr valve that could be all clogged up?
How does it run above 2500-3000 rpms?
Maybe its just your idle circuit that is clogged up.
Is your idle mixture screw (not your idle speed screw) turned out about 1.5 turns?
Happy to try to help over the thread if you can give some more information.
 1973 2002 Touring + Alpina A4  /  RHD
