Sign in to follow this
5 speed conversion
8 posts in this topic Last Reply
URL: file:///C:/Documents%20and%20Settings/Aashish%20Dalal/My%20Documents/1971%20bmw/pic1.jpeg
Hey-- I'm trying to figure out how much it costs (approximately) to properly do the five speed conversion on my 71 1600. My 69 has it, and I love it on the freeway. Anybody have any rough estimates? I have to rebuild the 4spd, but if I can do away with that in favor for the 5...
TIA
lemme try this...
Since your buying alot of used parts the price can really vary. The real expense comes in on labor. If you do it yourself this is a non-issue, but it's a fairly involved conversion, and if you pay to have it done it's going to end up pretty costly.
you can only link to pics and url's that are on line. The board doesn't upload your pic, it only links to it.
Hugo
URL: http://www.bmw2002faq.com/store/index.html
if you have a welder and can get one of those sweet $75 boneyard (hopefully you get a good one--bring a girl to the boneyard for luck ;p) trannys, and have a welder (or can borrow or rent one) then you can prolly do it for a few hundred. you need a new clutch kit to go with it, flywheel resurface (make sure they put a .020 "deck" on it--if they dont know what this is, find another machine shop), and you might as well rebuild the shifter. you need to shorten the driveshaft (can be $75-$200 depending on who you ask), a new $30 center bearing, etc. check www.2002parts.com for the kits. varco is about the only cat i'd scratch in this deparment... ;)
-Rob
URL: http://www.ifrance.com/myvision/BMW2002.htm
parts that you will need a welder for is the shift platform and the shifter linkage. They are available ready to go, but to me they are waaaaaaaaaay overpriced for what you get. Here is a link to the auto to 5 speed swap, is pretty close to the same is just more work going from a auto.
it very easy (even has oil). You don;t have to weld; you can bolt the trans mounts in. My personal mounting preference is the TEP trans brace ($110 or so).
