UPGRADE WIRING HELP NEEDED PLEASE...(long)
Okay, what is the procedure of adding a larger gauge wire from the alt. to the battery?
I read in someones 318i alt. conversion that if you go to a larger wire you get more charging power to the battery.
I have the 320i 65 amp alt. and have the two wires connected to the one that runs through the "sheath" that holds all the wires. Does the alt. wire go to the battery? Or does it split off somewhere in there? I really dont want to cut the cover to find out. What options do I have? Any help is greatly appreciated. TIA
