Completed stock air cleaner modification for Weber 38
URL: http://f1.pg.photos.yahoo.com/ph/mmiller2002/lst?.dir=/Air+cleaner
Pics link would have helped.
This was discussed a week or two ago.
Cut out the bottom "domed portion."
Left about 1/2" of the dome there to keep the filter element in place.
Had a ~11" diameter steel plate brazed to bottom.
Re-routed the crankcase vent hose.
Found the silver heat riser tubing that fit the snorkel.
Let me know if you see anything that needs attention.
Thanks
That could be an improvement, having the air make a nicer curve into the carb instead of having it tumble over the edge of the carb. But space is tight.
Looks good, BTW
Hugo
