Sign in to follow this
Distributor won't engage....help
6 posts in this topic Last Reply
After two hours of fighting with the exhaust manifold nuts and lots of time spent removing the head, now the &^%$F#$ distributor would not engage. I tried everything (manual tricks from clymer and others) for about an hour and was tired..left it as it is. It should not be like that...it goes half way in and stops, won't slide in. Is there a trick around this problem ?
TIA
keep on moving the shaft (cap off of course) clockwise and couterclockwise, just few degrees while you slide it down, maybe the gears just dont align up??
Pat
humm, i dont know about this chat room, is it part of this 02faq?
I cant install the needed files into this pc to access the chat room, controled by the pc guy here...need to log as "administrator"...what i am not.
And i am going to sleep now, anyway, it is 10pm here...
maybe some others will be able to help you on this.
cheers
Pat
Have mixd up some parts? Those 320/318 gears run the other way and are not interchangeable.
