Sign in to follow this
sheggaw
Ignition Key problem
3 posts / 600 viewsLast Reply
My brother in law trying to help move the car used the wrong key in the ignition, turned it in 1/3 of the way and got stuck. It has been about 2 years like that trying to figure out what the heck I am supposed to do. The other week I tried lubing it and using the some of the keys i have ( I have no clue with one he used) to turn it back to the original spot. I have had no luck at all. Right now we are starting the car with a screw driver (i had to separate the solinoid from the key). Beside bringing in some key master and try to sort it out, what can I do ?
thanks in advance
Remove lock cylinder from steering column have an automotive lock smith try the fix or plan on getting a replacement.
+1
I had similar problem. Removed cylinder and replaced it.
