LUCKY7402
74' 2002 automatic modded to 4spd
3 posts / 1208 viewsLast Reply
Year:: 1974
Make:: BMW
Model:: 2002
Price:: 5000 OBO
Unfortunately he doesn't have the time or funds to continue to tinker with it. I do have title in hand ready to sign over for a reasonable offer. The car does drive!! It was originally an automatic but the motor was swapped to a 4 speed stick shift.
Here are some of the upgrades:
Stage 2 motor l.e. 292 cam
New rear main
New drive shaft
New 228mm OEM BMW flywheel
New Sachs clutch less than 1k on it
New throw out bearing
Bosch blue coil
XR700 Optical Crane Ignition
Early Silver dollar gauge cluster
New brake master and slave cylinder with new clutch line and new reservoir
320i radiator with new hoses
Larger tropical fan
New thermostat
8mm red accel spark plug wires
Weber 40DFAV1 w/K&N air filter
New alternator hi amp
New s14 hi torque starter
Coolant bypass pipe for DCOE conversion
New fuse box cover
Crank case bottle catcher
New optima red top
New hell h4 headlights with new bulbs
New valve cover gasket
New rubber pedals and cluster rebuild kit
VDO cluster gauge new oil and volt meter with new OEM VDO sending unit
Hella 500 fog lights
new window sils
Nardi personal steering wheel 90s
Blistein HD sport shocks
H&R 1 1/4" drop sport springs
Suspension technique 22mm/19mm adjustable anti-sway bars
I.e. Big front brake kit new 320 hubs and bearings
Kevlar brake pads
I.e. Larger 320 rear drum upgrade and hubs
Poly eurothane bushing and new links
New center and driver tire rods
Differential was re-sealed about 2 years ago
Stahl header custom exhaust
ANSA exhaust
If you want parts or info call me and leave a message
9044827879
[email protected]
I will be free Friday thru Sunday
Happy 02ing
