Sign in to follow this
Okay, I will show my stupidity (lack of mechanical knowledge
11 posts in this topic Last Reply
Lately, I have had problems with my '76 non-tii engine. It fires up nicely and after the temp gauge gets around 3 o'clock position (10 minutes here in the frigid north), it will stall out. Starting it again is nearly impossible. This has happened on the road which can be frustrating. The car will be going into storage in a couple weeks so I do not want to spend a bunch of money on a tune-up, just to have it sit in storage for the winter. Since it starts fine and runs great until it's warmed I am thinking it's carb-related. It has a Weber 32/36 DGAV carb upgrade (common, I know) on it. I have sprayed carb cleaner in and around it and cleaned linkages with a toothbrush, but this has not helped. I think I will be taking it in to a shop soon. I just want to have some idea of what it could be before I go in. Also, I just want a quick fix to last me the one hour drive to get it to my parents barn for winter storage. I will deal with new plugs, points, rotor, condensor next spring.
Any suggestions would be greatly appreciated.
Chuck
carburetor icing. This was nearly always when the weather was between feezing and 40 degrees.
Use a bottle of dri-gas with the next fillup, and see if that cures it.
Delia (in Michigan)
Sounds like the choke is stuck closed. I don;t know that carb but.... You might try taking the filter off when the problem occurrs and looking down into the carb for a plate that is blocking the air flow. try lightly tapping it to see if you can get it unstuck. This plate is to restict air flow when the motor is cold as the percent of air to fuel to make the car run is different than when the car is warm. For some reason your is not opening after warm up as it should.
Are you talking products like Heat?
then it's getting too much fuel(not enough air) and flooding? Which would make it difficult to start again. Once it sits for a while (and dries out) it will start again. Sounds reasonable.
Any suggestions on how to get the plate not to stick? I cleaned/wiped with carb cleaner, but the problem persists.
Chuck
Any Wisconsin gas station should have some in the Fall and Winter months.
I'm not familiar with the brand names anymore. Since I have a tii, and all my other cars had FI, I haven't needed it in a while.
It acts like antifreeze for gasoline...keeps it from freezing.
Are you using a stock air cleaner and warm-up airbox?
Good Luck!
Delia
I'll try to post pics later. Not sure about the icing up, though. The car sits in my attached garage so the temp isn't too bad, yet.
Chuck
once the engine is warm try tapping on it with our fingers to shake it loose maybe? I am not so familiar with this carb so I dunno. If you can identify the plate (should be just inside the barrells of the carb) then by looking at the linkage you may find something getting stuck. Often these linkages have a stepped cam that sits against a screw. That is the high idle speed screw. This stepped linkage should swing out of the way and not come into contact with the screw thus allowing the choke to open.
Is it rainy and damp?
If it stalls and won't start immediately, but after 10 minutes, restarts, it might be icing.
It may also be starvation from a fuel pickup problem, either in the tank, a clogged fuel filter or weak fuel pump. Look in the trunk for a pinched fuel or vent line, too.
Delia
How do you check for a weak fuel pump?
I will go through the fuel system (tank to carb) and check for clogged filters, kinked lines, etc. As well as putting in some Dri-gas. Problem is I cannot run the car long enough to get the old fuel out of the system.
Chuck
...with me. It was good insurance. Easy to replace roadside, if necessary.
If you've never replaced yours, it might even be the factory original. Now might be a good time.
Delia
Delia
