Sign in to follow this
missing at higher rpms
2 posts in this topic Last Reply
I just replaced my starter and had the velocity stacks of my 45's
off. While they were off I used some carb cleaner to clean the
outside and ran some through the carbs as well.
After I got everything back together the car misses at above 3500
rpm. It idles fine and revs great, but during prolonged higher
rpms it misses.
I checked to make sure all plugs were firing and not fouled, I
sprayed some more carb cleaner to make sure nothing got
gummed up the first time. I also checked to make sure that the
distributer was tight and I feel pretty sure it didn't get accidentally
moved while I was messing with stuff. The brake booster vacuum
hose is on and in good shape.
Is there anything else i should check out before I take it in to the
shop (cringe).
TIA,
Dewar
possibly.
I'd pull the carb, take it apart a little at a time and clean it well.
how is it "missing"? is it popping, or just stuttering like no fire etc?
