Sign in to follow this
Will I need to shorten my driveshaft for a 5 speed if(more)
7 posts / 447 viewsLast Reply
I get a longneck diff driveshaft that has the slip joints
thanks in advance
flange. You'd have to make up some sort of adapter plate. You're going to be better of buying a shortened one from Dave Varco (aardvark racing).
Cheers!
John N
I can get a driveshaft shortened for 110 which isnt bad but if i can get one that will work without shortening that would be great
(nt)
The longneck driveshaft takes an eight bolt guibo, just like your regular 2002 driveshaft. The longneck driveshaft is about 9" shorter than a regular one, and it also has smaller u-joints, it would be way too short for what you want to use it for. But if you want one I have one for free in the east bay.
putting some money into shortening a driveshaft Thanks for the help i appreciate it
This info is from recent personal comparison of the driveshafts listed:
2002 long neck diff driveshafts, as mentioned, have a slip connection at the central u-joint, circlip retained u-joints, 4 bolt guibo flanges, and are much shorter than short neck units.
2002 short neck diff driveshafts have a fixed connection at the central u-joint, staked in u-joints, 4 bolt guibo flanges and are longer than short-neck units
2002 short neck diff AUTOMATIC TRANS units are similar to short neck standard trans units, but have a 3 bolt guibo flange that is SMALLER than all other flanges. Although auto trans driveshafts are a bit shorter than 4 speed driveshafts, they are NOT short enough to use with a 5 speed, even if the auto trans output flange fit the 5 speed.
320 5 speed driveshafts have fixed center connection at the u-joint, staked-in u-joints and EITHER a 4 bolt flange (early) or a 3 bolt flange (late).
E30 driveshafts have a central slip joint, staked-in u-joints and a 3 bolt guibo flange that is MUCH LARGER than the 320 flange.
Hope this helps......
