Indicator switch - possible to clean?
left turn single does not always blink - very slight pressure on the lever always solves the problem but is tedious when cornering and changing down. Pretty sure the problem is the switch, not the relay. Is that aerosol switch cleaner worth a try? Just seems like there is some crap in there causing a dodgy contact.
that there's a loose/broken wire internally that's making intermittent contact, so you might want to do some continuity testing on those little wires. The combination turn signal/wiper switches used on the 72s and 73s are the most notorious for this...
Mike
