Steering Box Rebuild
cbesing
Hi,
I have the fromt suspension and steering completely  removed and the steering box is not leaking and feels tight.  There is also more room in the adjument screw.  How can I test the box while removed?  Should I just do the rebuild since it is out of the car?  Also, I found the GL 4 lube as recommened in this board but could only find 140 wt.  Is this OK?
Thanks
Chris
See if these 2 links help you:
http://www.bmw2002faq.com/topic/153323-steering-box-re-assembly-question/
http://www.bmw2002faq.com/topic/116731-m20-triple-weber-build-x2/page-2#entry125800
Even though the second link says 'webers', it has good steering box info.
And I've heard that GL4 - 80/90W hypoid is advised.
Good luck!
-Bob
Great reponses!  Any idea how much play i should expect (with the box out o the car)?
Mine felt like zero play when I had it out of the car. However, once reinstalled, I did have noticeable free play.
I believe there's a torque value you're shooting for at the steering (not the adjuster) with the drag link disconnected.
I found it here somewhere but haven't gone back and followed it yet. I just gave it an 1/8 turn and called it good for now. I probably need another 1/8 turn or so but want to do it right when I have the time.
