Which bearings in vented disc
al
I am having a difficult time to find the correct bearings for my vented discs.
I went with the Volvo calipers and I thought I took my discs off a 79 320is. When I bought the set of bearings, they were too large for my hub. Maybe I don't remember correctly but which year uses those vented discs. Thanks in advance but I looked in the archives and saw some posts about them having two different sizes.
if you are using volvo calipers, then you have a normal strut, not a tii.  your conversion uses the same (small) bearinsg as your stock brake system.  you apparently bought the wrong bearings...the ones for a tii.
the bearings are specific to the strut and hub.  have nothing to do with the brake disks...
have you read the article on the vented brake conversion in the article section on this site?
