M20 323i 5 speed shortened shifter
camperman
I havent found any answers to this through the search:
I am building an M20 swap with a 323i 5 speed gearbox. As it sits, the gear selector input shaft (that goes into the gearbox itself) sits further back than a normal M10 5 speed swap. In fact, the end of the selector shaft is right in the middle of the tunnel hole for the stock shifter location. This means I cannot shorten my shifter platform enough to put the shifter in the stock location unless I attach the shifter straight onto the input shaft and remove the pivot rod that normally links in-between altogether.
Is it possible to attach the shifter straight onto the selector shaft and still shift gears?
I do not want to move the shifter if I can get away with it, as firstly I'd have to build a new centre console and second, theres a big hole in my carpet that is impossible to fill in surreptitiously.... ;)
Thanks in advance
Thats strange, because on my m20 swap that I am currently doing with the g260, which I had to create a new trans tunnel for from the shifter hole forward fits and the selector rod shows up right at the hole, is your engine sitting really far back?
