Sign in to follow this
YOU ASKED FOR IT ..
14 posts in this topic Last Reply
URL: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2438837573&category=33690
I TEST MARKETED MY FIRST ONE WRENCH DIZZY CLAMP
ON E-BAY LAST WEEK AND IT WAS A SUCCESS .
SOMEONE ON THIS BOARD COMPLAINED ABOUT THE 10 DAY AUCTION
SO I AM SELLING THE NEXT ONE IN 5 DAYS .
I AM REFINING MY MANUFACTRING PROCESS NOW SO I WILL
BE ABLE TO FIGURE OUT WHAT IT COSTS TO MAKE ONE .
I WILL BE SELLING THEM OFF E-BAY .
It might only take one wrench to tighten, but it will corrode
shut and you'll need an air gun to release it (OK, only one air
gun, but still)
Hugo
Fed up with years of needing two wrenches, last summer I had a friend weld a U shaped piece of scrap to a spare distributor bolt. Not as pretty as yours but gets it done. Good work RS!
OR THE OTHER WAY AROUND ? STAINLESS IS NOT BATTERY ACID .
ANYTIME A FREEOUS METAL IS IN DIRECT CONTACT WITH ALUMINUM ,
IT SETS UP AN ELECTROLISYS . THIS IS A VERY SLOW PROCESS THAT CAN
CAUSE THEM TO SEIZE .) THAT IS WHY STEEL LUGNUTS CAN SEIZE IN ALLOY WHEELS )IT TAKES YEARS .
IT DOESN'T MATTER HERE - ONLY THE ANTI TWISTY CAP ON
THIS BOLT IS STAINLESS THE REST IS PLATED STEEL .
THE SAME AS BMW USED IN THE FIRST PLACE .
Both SS and alloy are not corrosion-free, they corrode like hell, actually. Fortunately, the oxides on SS and alloy are not penetrable for more oxigen, so once there is a closed layer on the top the corroding stops. Unlike steel, which creates a penetrable oxide on top which allows more oxigen to enter deeper into the material.
Now for the Alloy and SS combo. When you connect these two, the oxide-layer that forms on them becomes one layer, connected to both the alloy and the SS. They don't get their own layer each. Hence, break out the heavy machinery to take them apart again.
Hugo
Don't know which way he went but it one or the other.....Marty.....
John Delorean is still alive.
