Help identifying wires/connectors (During the disassembly of my '02)
MildSeven
Hi guys,
I'm currently taking apart my 2002 to prepare it for painting, I'm the 4th owner, 3rd "enthusiast" owner. I've come across a few wires which aren't connected to anything.
I'd like to identify them and their use, if useless, I'll go through the harness to remove them completely.
Unused connecters/wires
Bellow windshield:
3x small connectors
post-46694-0-85372100-1423504450_thumb.j
Around brake booster:
2x large connectors, 1x medium, 2x small, 2x single
post-46694-0-37371500-1423504481_thumb.j
Next to distributor:
1x small connector
post-46694-0-41482200-1423504942_thumb.j
thanks a lot guys!
Anthony
Most of those wires look like part of the smog wiring harness.  Everything in the blue harness can be removed from the coil to the fuse box (2 wires).  You will need to run a wire back from the fuse box to the + side of the coil.  Lot's of write-ups on the FAQ that covers this procedure for coils with internal and external resistors.
Mark92131
I believe this is an oversimplification.
That blue housing contains the oil pressure wire, idle shut off solenoid wire, condenser wire(s)... it also depends on whether you are using an inline resistor wire (and a coil which is not blue).
The [unused two wires] in your photo look like the ones that went to the condenser.  I am guessing you had a Pertronix, or something similar and were not using them.  They are nice to leave inline, in case the electronic module fails.  Points can be easily plugged in to get you home.
There are some very complete threads to aid in de-smogging.
...also there are 2 unused connectors behind each headlight.
eg.: passenger side "unused." didn't snap photo of other side.
Square taillight cars came with two additional "switched" power feeds on the radiator support: each one ends with a clear rectangular connector. One is powered only when low beams are on: that one is intended to power fog lights. The other is powered only when high beams are on: that one is intended to power driving lights. I don't recall which feed is on which side of the radiator. You'll have to experiment.
thanks for the explanation. I also found a similar situation in the truck.
driver side (looks like the wire on the right of the connector connects to it... not sure)
post-46694-0-74859000-1424876301_thumb.j
passenger side: (same thing, looks like teh wire below the connect connects to it... not sure)
post-46694-0-27667600-1424877199_thumb.j
ALSO...When I was pulling wires in through the firewall... this one came in unlabelled, I went through my photos and couldn't find it anywhere :( anyone have any ideas?
post-46694-0-09404800-1424877035_thumb.j
These colored wiring diagrams are nice to have:  http://www.colorwiringdiagrams.com/bmwcars.htm
(you would want '2002F' for your '76)
williamggruff posted a copy in this thread, http://www.bmw2002faq.com/topic/160230-76-wiring-diagram-key/?hl=%2Bwiring+%2Bdiagram#entry1011382 , which can be found here:   https://plus.google.com/photos/104033389162157892781/albums/5428118103269140273/5428117186052531682?authkey=CI7OirTpnKbDPA&pid=5428117186052531682&oid=104033389162157892781
I am not sure about the  plug in your photo.  It looks similar in size to the plug going to the wiper motor, but mine is round and has five wires.  You should be able to figure it out with the wiring diagram though.
williamgruff posted a copy in this thread, http://www.bmw2002faq.com/topic/160230-76-wiring-diagram-key/?hl=%2Bwiring+%2Bdiagram#entry1011382 , which can be found here:   https://plus.google.com/photos/104033389162157892781/albums/5428118103269140273/5428117186052531682?authkey=CI7OirTpnKbDPA&pid=5428117186052531682&oid=104033389162157892781
thanks a lot, dude!
I honestly couldn't tell you what this is except that it has something to do with the speedometer- because I have this plug too. Here's a few photos, maybe they'll help.
Cheers,
Leit
Cheers,
Leit
that entire box can be removed if you get a 1pc speedo cable from an earlier car.  It's a rev counter that turns on the "emissions" light every xx,xxx miles.  Not needed.
Well the combination of your replies helped me out on this one :)
I didn't have the rev counter box, must not have been connected anywhere.
Thanks guys!
