Gas pedal lever adjustment
TurkisM2002
Hey guys I've spent an hour searching on the board for the proper way to reinstall the throttle lever. I'm performing an M20 swap and I'm using a lokar cable. I'm in the process of fabbing some stops and brackets and did a complete restoration of my pedal box.
My question is this. How should the lower lever be installed relative to the position of the gas pedal? Does it matter? If the pedal were pushed all the way to the floor, how should the lever be angled? Or is it entirely dependent on how the throttle cable is adjusted?
Thanks
