Sign in to follow this
'02 ball joint height
10 posts in this topic Last Reply
has anyone had a problem with clearance
between the control arm and the bottom of the strut
after installing the new type ball joints which now
only mount from the bottom of the control arm? i
have rebuilt the front end with all new parts and
now the car will not steer. part of the problem is
that the car is just a shell at this point and the front
suspension is completely unloaded putting the
control arms at a severe angle. i suppose that the
weight of the motor/trans ect. will change the
relationship of the control arm and steering arm
and there might be just enough clearance but it
doesn't seem correct that the wheels would not
steer if the car were on a lift i.e. unloaded as it is
now. my parts guy says that he has never had an
issue with these ball joints in 20 yrs. is there a
spacer or bushing inside the steering arm that i
don't know about?
"the new type ball joints which now only mount from the bottom of the control arm?"
Are you sure it mnounts from under the control arm? I believe that it is your problem. Try to bolt it from tghe top, it will solve your problem...
after discovering the problem the first time i took
the entire assembly off the car back to the shop
that did the work thinking that the ball joints were
not installed correctly. however they will only fit from
the bottom and the parts house confirms that they
are only meant to go in from the bottom. it seems
amazing to me that this has not been a major
problem in the past. they sent two replacement ball
joints (my cost) but they are exactly the same. i
read somewhere on this board about someone
'drawing" the joints down from the top into position.
i tried this and it seemed wildly dangerous as the
mating surfaces do not touch.
Look at you old ball joints (assuming the're still laying around in the corner of the garage) and compare -just a rough casting on the new bits.
thanks for the info.
it is a bit strange that you would have to do that
though, don't you think? i have someone who is
going to bring this up to the moog people anyway.
seems like a lot to ask grinding on a new part just
to drop in a ball joint. it's an '02 not a freakin'
bugatti or something.
But in this case it is easy to remedy.
thank's again
this may or may not be news but i just discovered
that one of the four ball joint kits i now have in my
possession is machined and not cast. this one fits
like it should. no grindind required. i tried grindind
on one of the ball joints that are cast and i still don't
like the way it fits. the casting is beveled where it
meets the flange and will not seat all the way
down. all in all 3 of the 4 ball joints are diffrent even
though they have the same part no. stamped on
the bottom. i'm going to contact the parts place and
see if they can dig out another machined one. i
would suggest to anyone else to do the same. it
fits so much better.
with. I went round and round with Bavarian with mine.
Sent me two different ones. Got a new front end sitting in boxes and the last thing I need is problems. Mine are TRW with TRW ground off with Moog
stamped over it.Go figure.
