Question, stock location upgraded sway bar versus Ireland's
What I mean is that i have a 19mm front bar mounted with its associated hardware to the subframe in its stock location. Is Irelands bar better and how, I noticed in a couple of pictures these large aluminum blocks used to mount the sway bar and was curious if these are the Ireland bars in question.
Thanks......
After you answer a whole bunch of questions like: Street/Track? Soft/Firm/Hard? DailyDriver/"Fun"? Lowered? Goals? Ground clearance? etc.etc.
Then it's a simple matter of doing the math. Exterior diameter(& inside if its hollow), length, length of lever arm, width, etc and your answer magically appears.
Enjoy.
