Hi,
I am running flipped solid  mounts on my rear subframe. it works great however I did not do any thing for the diff. I am now in the process of doing a 5 speed swap and I want to make sure all the drive line angles are ok. Am I worrying too much about this?  Does anyone know if one can purchase offset bushings for the diff to raise it up in the car as much as the front of the rear subframe? Worst case I can make some on a lathe.
So you didn't do anything for the differential? I am running prothane diff bushings which are a lot stiffer than the factory ones. since they are stiffer they don't allow the rear of the diff to come up in the mount
no I didnt do anything. Never had any ill effects in 40k miles
