removing the alternator - get it past the 22mm dinan sway ba
pulley with an air impact wrench. You can then twist the alternator a bit an drop it past the sway bar. Put the replacement back up past the sway bar without pulley, and resting it on the bar you can reattach the pulley with the impact wrench. Then put it back up into the bracket and reattach. I've done this several times on my tii.
Eric
