32/36 idle cutoff solinoid & primary idle jet problem
Just curious. Is the primary idle jet supposed to FREELY slide on the Solinoid shaft? Mine hangs up a little, does not slide back & forth freely. If I rotate the jet a little it slides freely, rotate it a little more & it sticks.
Wonder if this is causing my poor idle..
Can I replace the solinoid with a Jet holder screw like the one that is used on the secondary side?
Thnx
John L
Lafayette hill PA
of the solenoid in carb cleaner. It's possible that there's a little bit of crud in there that's causing the sticking, and carb cleaner will dissolve it. Pull jet, squirt, wait, squirt again, then test.
Mike
