Oil Filter Housing Bolt Torque Spec
NullZwei
I cannot find any specs for the above referenced bolts, not on the FAQ, not in the Blue Book or the Haynes manual.  Does anyone have the definitive torque specs for these bolts?  In looking at the specs for other 8mm bolts that are threaded into the block, it appears 18 ft. lbs. is the recommendation but I wanted to be certain that number was appropriate for the oil filter housing as well.  Thanks for any assistance.
