Sold - Fully Built M10 motor - Turbo - $3000
Sold - 1/30/15
I purchased this built motor from another FAQ member in June of 2012.  I intended to pull the weak motor from my 1974 tii, and replace it with this.  Out of concern for originality and overall laziness, it never happened.  Its time to move on, so the motor needs to go.
Link to the original ad http://www.bmw2002faq.com/topic/129947-fully-built-brand-new-insane-m10-motor-turbo/?hl=m10#entry63219
The details!:
Everything is brand new, never been run
It is best suited for a force induction build because of the lower compression ratio.
My plan was to have 350 whp and this should hold that, and then some!
HEAD:
From '84 318i (best flowing head)
fully assembled
~8000 RPM Valve train
Fresh valve job
Ported
Stainless Steel valves(These might be oversized, will double check)
EDIT^^ The valves are not brand new but were cleaned up, one of them as a slightly different recess as well, won't make any difference though
Titanium retainers
Korman Dual Valve springs
Korman light weight rocker arms
Schrick 284
Head work was performed at Top End Performance in North Hollywood, Ca
SHORT BLOCK
Short block assembled
1.8L block (lighter than 2.0 one)
Metric Mechanic sourced Forged Pistons (8.25 to 1 compression) EDIT: 89mm
lightened 2.0 crankshaft(shot peened, polished, and balanced)
Raceware main cap studs
ARP rod bolts
Mechart connecting rods
New rings, pins, bearings
Block machine work was done at Bob Lambeck Enterprises in Northridge, Ca
Please contact me at [email protected]<script type="text/javascript"> /* */ </script> with any questions.
post-40923-0-06804900-1417370439_thumb.j
post-40923-0-67005400-1417370439_thumb.j
post-40923-0-24924600-1417370440_thumb.j
post-40923-0-83967000-1417370440_thumb.j
post-40923-0-71988200-1417370441_thumb.j
post-40923-0-47810400-1417370442_thumb.j
post-40923-0-09877700-1417370443_thumb.j
post-40923-0-86801200-1417370454_thumb.j
post-40923-0-66821600-1417370455_thumb.j
post-40923-0-47222500-1417370456_thumb.j
post-40923-0-15017700-1417370457_thumb.j
  • 4 weeks later...
  • 3 weeks later...
