tii has oscillating idle?
Nada, as you see someone has suggested a vacuum leak
but near as I can tell there is only one vacuum line and
appears to be ok. I'll snoop over the weekend to see if I can
find the culprit. It idled fine then a sudden change. Must be
that it doesn't like its new owner? Sounds like you're getting
yours sorted out. Cort.
spray some starting fluid around and see if it
affects the idle, make sure you have a fire
extinguisher and stay away, the stuff is highly
flamable. good luck, please report back.
tube to the throttle body or next to it is a bracket that attaches to the body, which is secured by two bolts they could back out and this will leave a open hole into the body.
gaskets and hoses, if the motor stumbles you just found your leak. Or you can try the starter fluid or propane method and listen for the rpm zing.
