Austin mini 13" minilites
Sheepdog
I thought the old Mini's had 10" rims, which were upgraded to 12" rims sometime in the '70s. If that's true, maybe those 13" Minilites aren't technically "Mini rims."
For a 2002, you need the 4x100 PCD, a hub center bore of at least 57.1mm, and an optimal offset of 25-28mm for a 5" or 5 1/2"-wide rim. You've got some flexibility from that point.
Good luck,
