Differential seals
I have a leaking seal on the output flange of the differential. Can the output flange be removed with a standard gear puller or is the funky puller that is shown in the factory manual needed. ( It bridges the flange vice pushing through the center)TIA
The way I pull them is use a standard puller a long bolt.
Take out the bolt in the center of the output flange
Get a longer bolt (I have a designated bolt M12x1.5, 120mm long) of the same thread and put a dimple in the top of the head with a drill bit
Thread the longer bolt into the hole about 6 to 8 turns
Use a standard puller with the legs on the circle of the output flange and the threaded center part in the dimple of the bolt.
The way I pull them is use a standard puller and a long bolt.
Thanks, that sounds much easier than fabricating something like what is shown in the factory manual. Side question, what type of loktite did you use on reassembly?
I usually don't use any, but the car is torn down enough that it's never been a problem. The manual says to use Loctite is there is play in the splines but I have never experianced any play. If I needed to use Loctite, I would use Red (high strength) Loctite.
