M20 Motor Mount Swap Question
turboninja22
Got this off of a blog
"Unless your motor mounts are new(in which case you can use a 2002 drivers side motor mount) replace the motor mount. A single E30 motor mount(they’re identical on both sides) works just as good, if not a bit better, than the driver’s side ’02 mount and it’s about ¼ the price of the ’02 mount. You will need to use the factory ’02 passenger side mount."
So according to this write up there is no custom motor mounting bracket I need to make, I just get the right mounts from the e30 and O2 and it just drops in?
I am going the getrag 245 rout with the 323 casing and drive shaft shorten.
